Hello everyone
Can anyone tell me why i can`t do a flat pattern with this item (B5A-01)?
I did the same thing with another item (B5C-04) but with a different radius & a different cut & it worked fine.
Why is this item an exception?
I've attached the two item in question.
I`m using Inv. 2011
Dan,
Solved by DanielCTurcotte. Go to Solution.
Does it need a rip or tear location so the software knows where to unroll from?
@JimSteinmeyer wrote:Does it need a rip or tear location so the software knows where to unroll from?
It has one.. But he is also missing constraints/dimensions in his first sketches which is NEVER good and will always cause problems like this.
Seems the delete face is causing the problem too..
Thank you for the response!!
I`ve tried to constraint completely my sketch like you suggested, but to no avail.
What do you mean by the deleted face could be the problem? How could it be a problem?
And how can i fix it?
Thank you!
Dan,
I found the problem.
For those interested , the plane that i used for cutting my pipe was to close from my origin Center Point.
I just had to put it farther to fix the problem.
