Inventor Forum
Problem with Dimensioning in .idw
2 REPLIES 2
lusacd
305 Views, 2 Replies
I designed a simple pull-out dowel but when I dimension or attempt to retrieve dimensions in .idw, my dimensions display on a 45 degree angle.
2 REPLIES 2
rhasell
in reply to: lusacd
Hi
I am sure someone will be able to explain exactly why, View orientation etc
But try this
 -Right click on the view
- Change "General Dimension type" to True (Or if already on "true", change to "projected")
Reg
2024.2
Please Accept as a solution / Kudos
Cadmanto
in reply to: lusacd
Have you checked the styles editor to see if the default for this dimension style has changed?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
