Dear All,
I am facing problem with copy command in assly mode.
I have to copy pattern. and have to insert with base point at some other place. ( like autocad) i am not getting how to do it. Is it possible to copy object with base point and paste with that base point.( find attahchment)
Pls help.
Thanks and Regards,
Datta Indalkar
Hi indalkar.dattatray,
Rather than copying the pattern, you can likely just pattern the first pattern, which will create the copies in the correct place.
Depending upon how you created the hole pattern in the part file, you might also be able to use the Feature Pattern Select option to just place the bolt into every hole in the part pattern automatically.
I hope this helps.
Curtis
