Inventor General Discussion
Active Contributor
4 Kudos
Post 1 of 2
Problem with copy command in assly .
88 Views, 1 Replies
07-13-2012 09:22 PM
Dear All,
I am facing problem with copy command in assly mode.
I have to copy pattern. and have to insert with base point at some other place. ( like autocad) i am not getting how to do it. Is it possible to copy object with base point and paste with that base point.(  find attahchment)
Pls help.
Thanks and Regards,
Datta Indalkar
With Warm Regards,
Datta Indalkar.
1,701 Kudos
Post 2 of 2
Re: Problem with copy command in assly .
07-13-2012 09:40 PM in reply to: indalkar.dattatray
Hi indalkar.dattatray,
Rather than copying the pattern, you can likely just pattern the first pattern, which will create the copies in the correct  place.
Depending upon how you created the hole pattern in the part file, you might also be able to use the Feature Pattern Select option to just place the bolt into every hole in the part pattern automatically.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
