Can you post the part, zipped?
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5922412@discussion.autodesk.com...
I try to perform a tapered thread profile by using the coil option,
I defined the pitch, taper and revolution.
In this particular case my pitch has the same width than the insert I am
using to remove material and I got the following error.
"Edit coilt feature failed, Modeling failure in ASM".
The only way I found to solve this problem is to change the pitch in the
fourth decimal (0.0001), so I am cheating the software to perform my part,
but I think AutoDesk should have a technical solution for this problem.
I need to perform a coil but having the insert widder than the pitch
Your help will be highly appreciate than otherwise we will have to change to
a different 3D modeling software.
We know that Siemens NX can perform a thread in this way.
Thanks and Regards,
