Inventor Forum
Problem with circular pattern
3 REPLIES 3
1641 Views, 3 Replies
So, i'm trying to replicate a feature using the circular pattern tool but, for some reason, i can't select the axis that i chose. I'm a bit of a newbie, i'm sorry if i'm making a basic question.
3 REPLIES 3
wimann
Hi there Ralien and welcome to the forums.
Part files help. However, I can't imagine circular pattern not allowing you to pick an axis. If you don't have a geometric axis (ie a cylinder or some other axial part) then you may need a user axis to help define the circular pattern but other than that, I can't imagine what could cause the problem without having the part file in hand.
Hope this helps.
-Will Mann
Inventor Professional 2020
Vault Professional 2020
AutoCAD Mechanical 2020
in reply to: wimann
Yes, that should be the problem, can you tell me how to make an user axis?
Nevermind i found out, it worked, thanks a lot for the help!
