Solved by wimann. Go to Solution.
Hi there Ralien and welcome to the forums.
Part files help. However, I can't imagine circular pattern not allowing you to pick an axis. If you don't have a geometric axis (ie a cylinder or some other axial part) then you may need a user axis to help define the circular pattern but other than that, I can't imagine what could cause the problem without having the part file in hand.
Hope this helps.
