I am having problems with changing the height of the dimension text. I have tried going into the style editor and changing the text height in there and then saving it. The number for the height that I changed stays saved however the actual text height on the drawing does not, not even after I tell it to update. Any help on what I might be doing wrong will be greatly appreciated.
Thank you for your help however, sadly, those tutorials did not have anything on edditing the text height. thank you though.
Seeing as the process is that you define a text style then go to the dimension style and say 'use this text style', have you tried creating a brand new text style with a brand new font (along with a new size) and then going to your dimension and changing it's font style and seeing what happens?
There's also the possibility you're changing the wrong text style, or the dimensions you're trying to change aren't the style you think they are. You may want to double check that the dimension style for the dimenisons in question is actually the style you think it is and that the correct text style is loaded into the dimension style.
If all that checks out, what i'd do is start a brand new drawing sheet (all new .idw) and see if i can get the dims to work right there. If I can, it wouldn't be the first time something got messed up in an idw or dwg file. Had an odd problem like that this week.
