Show only
Search instead for
Hi everybody.
I have problem to create a corner in 45 grades. I need a real 45 grades of Corner when start and end in the last poin.
In this example i send a file, the problem is these hole that make the corner command.
I'm working with Inventor Version 7. Any have a solution for this problem__?
Thank you!
Could you send the part to johnsonDOTshiueATautodeskDOTcom, so I can take a
look?
Thanks!
Johnson Shiue
Test Engineer
Autodesk, Inc.
wrote in message news:5178240@discussion.autodesk.com...
Hi everybody.
corner command.
Thank you!
hi
thanks for the fast answer.
well, i don't see your email, so, i send the file to this page, if you have any comment about this problem, mi email is gerardordzn@gmail.com.
these is the file
thanks you!!!
