Thanks, it seems to solve the problem.
"Kent Keller" wrote in message
news:403cda5e_3@newsprd01...
> If you bump up the gap a little on the contour flange corners, (I used
2/64) it seems to
> work.
> Kent
> Assistant Moderator
> Autodesk Discussion Forum Moderator Program
> "Domnic Brunelle" wrote in message
news:403cd313_2@newsprd01...
> > This new version give the same error even though I moved the sketch. I
also
> > tried other things like : Flange/width starting on the opposite side of
the
> > edge, using flange instead of contour, ...
> > Help again...
> > "Matt Hendey" wrote in message
> > news:403cb6b3_3@newsprd01...
> > > The position of ContourFlange3's sketch causes the sheet metal offset
to
> > > intersect the ContourFlange2. This seams to be the problem even though
you
> > > used an offset. Moving your sketch to the right may be a better
method.
> > > Matt
