I am not able to save copy as Autocad dwg. I get this : Problems encountered while saving the document. Its a new installation of inventor 2014 SP1 hotfix 2 on windows 8.1. Maybe windows is the problems.
Any suggestion ?
Can you post an image of what you are seeing? Is it an error message or is it that the file extention is not available.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
File extension is available but options button is greyed out. When I click save, i get the prompt saying :
It will be greyed out because it already is an Autocad drawing (.dwg). What options would you be looking for anyway?
Hello vmcarbonneau,
Please try the solution proposed in the thread below and see if it helps in your case:
http://forums.autodesk.com/t5/Inventor-General/Importing-a-dwg-into-a-ipt/m-p/4708455#M492533
If Cesar's option does not work, can you post the file you are having issues with?
Is this the only file this is doing it for or is this issue accross the board?
Someone I work with actually had this problem yesterday - are your views set as raster only? When we changed the views to precise that fixed the problem and the .dwg was able to generate.
Thanks for the reply. No views not checked for raster only. The error I'm seeing is very generic- "Problems encountered while saving. I even renamed the registry as suggested by B.Holland from Autodesk (name of person may be mispelled was from a post I no longer have opened) to no avail. But going thru the old threads there seems to be alot of issues with this functionality in 2014. When someone figures it out I hope they let me know. I'm assuming this is a glitch and there will be an SPO or hot fix for this eventually.
I tired the linked solution above (did everything as I supposed), but when I type inventor /install it says 'inventor' is notrecognized as an internal or external commad, operable program or batch file.
I'm using an Inventor 2014 student version under Windows 8.1 64bit.
Does somebody know how to fix it?
