Inventor Forum
Problem reading new messages in outlined newsgroup
4 REPLIES 4
157 Views, 4 Replies
Would have this posted on IV 5.3, 6 & 7 newsgroup, but it may not be readable: My problem here is: I am able to read all messages (new and old) in news://discussion.autodesk.com/autodesk.inventor.8 I am unable to read new messages, same appear as "Message is no longer available on the server" in: news://discussion.autodesk.com/autodesk.inventor.7 news://discussion.autodesk.com/autodesk.inventor.6 news://discussion.autodesk.com/autodesk.inventor.5.3 Please advise Wolfe
4 REPLIES 4
Try resetting the other groups... -- Sean Dotson, PE Autodesk Inventor Certified Expert http://www.sdotson.com Check the Inventor FAQ for most common questions www.sdotson.com/faq.html ----------------------------------------------------------------------- "Wolfe" wrote in message news:3fdf7a20$1_7@statler... > Would have this posted on IV 5.3, 6 & 7 newsgroup, but it may not be > readable: > > My problem here is: > I am able to read all messages (new and old) in > news://discussion.autodesk.com/autodesk.inventor.8 > > > I am unable to read new messages, same appear as "Message is no longer > available on the server" in: > news://discussion.autodesk.com/autodesk.inventor.7 > news://discussion.autodesk.com/autodesk.inventor.6 > news://discussion.autodesk.com/autodesk.inventor.5.3 > > > Please advise > Wolfe > >
You will have to reset the newsgroups. Right click on the group in the Folders window and choose properties, Then go to the Local File tab and hit reset. They should now be able to download messages again. You will loose all old message bodies by doing this, but you can re download them if you want. -- Kent "Wolfe" wrote in message news:3fdf7a20$1_7@statler... > Would have this posted on IV 5.3, 6 & 7 newsgroup, but it may not be > readable: > > Wolfe > >
Thanks Kent, Had a number of messages categorized as watch, have to relocate same again. But at least I can see the messages. Merry Christmas Wolfe "Kent Keller" wrote in message news:3fdf8f80$1_6@statler... > You will have to reset the newsgroups. Right click on the group in the Folders window and > choose properties, Then go to the Local File tab and hit reset. They should now be able > to download messages again. You will loose all old message bodies by doing this, but you > can re download them if you want. > > -- > Kent > > > "Wolfe" wrote in message news:3fdf7a20$1_7@statler... > > Would have this posted on IV 5.3, 6 & 7 newsgroup, but it may not be > > readable: > > > > Wolfe > > > > > >
jurgen_eco
This will be solved in the next release or Sp1....;o)
