Inventor General Discussion
0 Kudos
Post 1 of 4
PROBLEM ON 2D DRAWING Level of detail changes to "all disabled" INVENTOR 2011
256 Views, 3 Replies
02-15-2012 01:21 AM
I have a terrible problem!
When I open an assembly 2D drawing, it opens with no views and any indications. Views appear with "all disabled" level of detail. It has changed automaticly and when I change to "Main" level of detail, it shows correctly views but all work I've done with notes and messures has dissapeared.
If there any way to open it with all views in Main level of detail activated by defect? (not posponing updates on open)
Thank you all!
______________________________
TERMISA ENERGIA S.A.
http:\\www.termisa.es
Employee
0 Kudos
Post 2 of 4
Re: PROBLEM ON 2D DRAWING Level of detail changes to "all disabled" IN
02-20-2012 04:10 AM in reply to: adelgado
Did it happen only once with a particular idw? Or can you reproduce it with any other idw? If it is just the particular idw with the assembly, would you upload the dataset so we may check the problem.
Thank you!
-Jozef
Member
0 Kudos
Post 3 of 4
09-27-2012 09:36 AM in reply to: adelgado
I am having a similar issue with the LOD changing to whatever the IAM's LOD was set to.
Is there a resolution for the IDW drawing view not changing LOD?
780 Kudos
Post 4 of 4
09-27-2012 03:46 PM in reply to: ken.kaiser
Not sure why you are having this problem, but LOD is primarly designed to reduce the memory foot print of your model while working in the modeling eviroment.
You really should be looking at View-Rep for work with drawings as this is what it is designed for.
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
