Inventor Forum
PROBLEM ON 2D DRAWING Level of detail changes to "all disabled" INVENTOR 2011
3 REPLIES 3
adelgado
403 Views, 3 Replies
I have a terrible problem!
When I open an assembly 2D drawing, it opens with no views and any indications. Views appear with "all disabled" level of detail. It has changed automaticly and when I change to "Main" level of detail, it shows correctly views but all work I've done with notes and messures has dissapeared.
If there any way to open it with all views in Main level of detail activated by defect? (not posponing updates on open)
Thank you all!
______________________________
TERMISA ENERGIA S.A.
http:\\www.termisa.es
Tags (1)
3 REPLIES 3
jozef.dubaj
in reply to: adelgado
Did it happen only once with a particular idw? Or can you reproduce it with any other idw? If it is just the particular idw with the assembly, would you upload the dataset so we may check the problem.
Thank you!
-Jozef
ken_kaiser
I am having a similar issue with the LOD changing to whatever the IAM's LOD was set to.
Is there a resolution for the IDW drawing view not changing LOD?
blair
in reply to: ken_kaiser
Not sure why you are having this problem, but LOD is primarly designed to reduce the memory foot print of your model while working in the modeling eviroment.
You really should be looking at View-Rep for work with drawings as this is what it is designed for.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
