Inventor General Discussion
0 Kudos
Post 1 of 12
Problem: Linked Parameters Not Updating - Inventor 2011
1138 Views, 11 Replies
04-11-2010 03:36 AM
I can't link parameters properly with xlsx/xls files. At the beginning it works well, but if I change files the parameters can't get updated- all fields get yellow instead. It helps only when I relink the file.
391 Kudos
Post 2 of 12
Re: Problem: Linked Parameters Not Updating - Inventor 2011
04-11-2010 03:50 PM in reply to: domel123
Which OS? Which version of office? Can you post the dataset. no one can help you properly without this info. There have been issues with inv 2011, windows 7 and office 2007, there is heaps of info on this forum if you search for it.
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
0 Kudos
Post 3 of 12
04-11-2010 04:13 PM in reply to: domel123
Win 7, Office 2007:
When it happens:
I open a new part, open parameters, link simle excel file- now it works, but...
I open excel to edit file. I save and close file afterwards. I press Update in parameters and linked parameters get highlighted.
Temporary Solution: I can relink the file or rightclick the file path -> edit first cell -> and OK without changing.
But it would be difficult every single time.
Product Support
47 Kudos
Post 4 of 12
04-12-2010 09:34 PM in reply to: domel123
This is a known problem.
We are working on a hotfix for this.
Best worarounds are to
a) relink to teh same spreadsheet
b) edit teh start cell and pick the exact same cell.
Sorry for the inconvenience.
Bob
Autodesk Inventor Product Support
Member
0 Kudos
Post 5 of 12
05-26-2010 12:38 PM in reply to: domel123
We've just upgraded to Inventor 2011. I've been having the same trouble with Linked Parameters. I don't think its the operating system. We've been using XP-Professional 64Bit with the 2010 version. Relinking the file works but it becomes quite tedious to do when you're dealing with a large assembly. Has anyone tried contacting Autodesk to see if they're making a patch to fix the error?
658 Kudos
Post 6 of 12
05-26-2010 12:59 PM in reply to: domel123
> {quote:title=aj.schulte wrote:}{quote}We've just upgraded to Inventor 2011. I've been having the same trouble with Linked Parameters. I don't think its the operating system. We've been using XP-Professional 64Bit with the 2010 version. Relinking the file works but it becomes quite tedious to do when you're dealing with a large assembly. Has anyone tried contacting Autodesk to see if they're making a patch to fix the error? http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019
A hotfix has been released already.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Member
0 Kudos
Post 7 of 12
05-26-2010 01:16 PM in reply to: domel123
I've tried installing the hotfix from the link you sent but I am still having the same error with Linked Parameters. Are there any other solutions available?
Product Support
47 Kudos
Post 8 of 12
05-26-2010 02:59 PM in reply to: domel123
Using the "Edit start cell" context menu on the linked spreadsheet and leaving the start cell as is might be a faster workaround than relinking the spreadsheet.
Can you send a small dataset to bob.van.der.donck@autodesk.com that exposes the problem after installing hotfix http://usa.autodesk.com/getdoc/id=DL14965008 ?
I want to look at your case.
Bob
Member
0 Kudos
Post 9 of 12
05-26-2010 04:20 PM in reply to: domel123
That link for a hotfix corrected the issue. Thank you.
New Member
0 Kudos
Post 10 of 12
12-05-2012 11:16 PM in reply to: mcgyvr
Is there a Hotfix for 2013 Pro?
