From your pc spec's there are a few below-par components which could be
causing your performance issues.
1G ram - really need at least 2G min these days (probably more like 3G with
any curved surfaces parts or medium-sized assemblies), especially with the
Prof version which loads more into memory than the std version.
Quadro NVS - it's a 2d-specific gfx-card. They are intended for Excel and
Word, not 3d - If you're working with Direct 3D get a GeForce card (or
Quadro FX cards for Open GL mode).
You've got a quad-core processor which is usually overkill, so it's unlikely
to be the problem and certainly hampered by a bad gfx-card and severe lack
of ram.
Other areas to check - make sure ALL drivers are up to date, not just
gfx-card. Can have the latest, fastest, best gfx-card driver but if you've
got an out of date and/or bad chipset driver then it's all gone to waste.
Everything plugged into the pc, from mouse to soundcard all uses drivers
which take computer resources and memory (all talking to each other through
the mobo and it's chipset drivers) - if any 1 of these is a flunky release
and hogging resources it'll drag the rest down (especially with only 1G
ram).
Inventor - update all SP's and hardware lib's
Hope that helps
wrote in message news:6275044@discussion.autodesk.com...
We have a problem when rotating or zomming any part or assembly, there is a
delay in inventor response to the command (about 3 - 5 sec)
we are using Inventor 2009 Prof.
Windows XP 32 bit
Dell Precision T5400
1 G of Ram (will be upgraded soon to 4G, but we have some stations with 2G
and also have the same problem)
Quadro NVS 290 , Driver ver: 6.14.0011.8246
Intel Xeon quad core
Hardware : direct 3D
