Inventor Forum
Problem in Loft
2 REPLIES 2
akakumara
236 Views, 2 Replies
Problem in Loft
I am uploading a file that I am creating. I applied a surface loft but I got uneven result after applying replace face command, see the image.
Any suggestion for removing this...
Regards
Arun.
Tags (1)
2 REPLIES 2
mikejones
in reply to: akakumara
Try using Sculp instead of the replace face
Mike
Autodesk Certified Professional
akakumara
in reply to: mikejones
Thanks for the response but Mike the results are same after applying Sculpt, I think there should be some more rails or path in the loft which I am not able to imagine.
Regards
Arun.
