hi all,
I try to download update 2 SP 1 Inventor 2014 with this link
But when i click
DL-22744369.zip (zip - 16351Kb) |
always redirect to http://knowledge.autodesk.com/
Please, help.
Solved by RockDr. Go to Solution.
then this one: http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/update-2-in...
The links blair provided work for SP1 but the original poster was correct that there is a problem with the page on the new web site that has the Update 2. This update should be available through the Liveupdate feature of the product, but we'll get the web page fixed no later than tomorrow.
thanks for your respon,
but curently I was install Inventor 2014 SP 1,
when i try to download with this link ( i copas from your comment)
i can not download this, because link redirect to http://knowledge.autodesk.com.
Thanks RockDr
Thanks for this feeedback. We're working to correct the file links for that servcie pack and troubleshoting what happened to break them when migrating to the new site in the first place.
@RockDr wrote:The links blair provided work for SP1 but the original poster was correct that there is a problem with the page on the new web site that has the Update 2. This update should be available through the Liveupdate feature of the product, but we'll get the web page fixed no later than tomorrow.
Just an FYI --- the link is still broken!
It goes to this page:
http://knowledge.autodesk.com/ooooops
Edit: Sorry, I thought that was posted on 2-09, but now I see it was posted today (2-12). Just frustrated that there is confusion on which update 2 actually fixes the problem. Would have been nice if the fixed update had been named 2.1 or even 3.
The page has been corrected and is available at this URL:
http://knowledge.autodesk.com/article/DL22744369
or the full URL of the page is
thanks for your patience. It did indeed take longer than my previous post anticipated.
I wonder is it still that "improved second" version of Update 2 for SP1
...or is it the "first version" ... or may be already 3rd version?
Firstly published version was DL22744369.zip
Second contained dash in filename "DL-22744369.zip"
Now filename is again dash-less "DL22744369.zip".
...seems like somebody is kidding...
My congratulations - it is third version of Udpate 2 SP1 (I've compared its content with both previous and it does differ from both).
Well not update but readme was changed
Statement
"FEA Results incorrect compared to previous releases"
was replaced with
"Bonded contacts between cylindrical and planar faces can cause the geometry to behave overly stiff near the area of contact"
no comments
Should I install this update for Inventor 2014 LT? it is not listed under the applications.
Roger
