I don't know if this will work as it involved two different types of geometry, activate the Dimension function, select the
upright centre-line, RMB and select Intersection, select the horizontal line. Do the same with the angled line. RMB and select
Horizontal Dimension.
HTH
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be
as mad as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
http://support.microsoft.com/default.aspx/kb/555375
wrote in message news:5851995@discussion.autodesk.com...
I need to add a dimension to an Inventor Dwg and I'm having some problems. I need to place a horizontal dimension that shows
the distance between the intersection of two w-flange centerlines. I've attached a screen shot that shows what I'm taking
about.
In Autocad I would just use the "INT" Osnap. However, Inventor won't allow me to pick the intersection of these two
centerlines (shown outlines by white ellipses). I could make a sketch and project the g
eometry. But that seems like a "round about" way of getting the job done. Tell me that there is an easier way!
Thank You,
D. Greco
