I am trying to batch plot a series of IDW drawings through task scheduler, the results is the wrong proportions and size, I am wondering if there is setup command in task scheduler that can be modified or if the proportions are wrong due to the IDW setup within Inventor itself i.e. page not setup correctly, thanks
Solved by Nicolas.Bourquin. Go to Solution.
Dear Anthony,
In the task scheduler, during the creation of a printing task, after the selection of a folder containing the idw or dwg to print for example (or directly the idw or dwg files), if you select (click on it) the folder (or the file) in the "print file" display box, the "option" button is then available where you can define a printer, a size, priniting scale,...
I hope that can help.
Best regards
Hi Nicolas, that was exactly what I was looking for, thank you very much for such a thorough and concise answer
