style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"DonA" <djanneken@fuse.net>Dave,
wrote in message
href="news:f14288c.58@WebX.maYIadrTaRb">news:f14288c.58@WebX.maYIadrTaRb...
So long as you select the "Model 1:1" in the "Scale" area of the
"Print" dialog box, then everything you print will printed "exact" size to
what ever it is you have drawn. If you have it drawn at 1:1 then the printout
will be 1:1. If you have it drawn at 4:1, then the printout will be at 4:1.
If you have it drawn on a "A" size and print on a 8.5 x 11 paper then
it will all fit. If you have it drawn on a different size ("B", "C"...) then
only part will fit on a 8.5 x 11... BUT what does fit will be at the correct
scale I.E. same scale it was drawn at.
So if you want 1:1, then draw
1:1 and select "Model 1:1".
25" is 25" so no matter what you do if you
want 1:1, then in that case the paper must also be >=25".
Based on
all the posts though, I am not sure that what I have just said is what you
really want. My appologies if I am off base here.
Don
A 🙂
"Dave J" <
href="mailto:davej@autoconcorp.com">davej@autoconcorp.com> wrote in
message
href="news:42D5F5E396249212851B9656199F3326@in.WebX.maYIadrTaRb">news:42D5F5E396249212851B9656199......
*sigh*
No, this isn't what I want.
We make prints to E size (36 x 48). The assembly
is usually 1:4 scale. I can print to 36" roll paper without a hitch. But
often, I'm asked to print a small area of the drawing (could be anywhere) to a
certain scale (it may be 1/4 size, 1/2 or even full scale) on 11x17 or 8.5 x
11 paper. Don't ask why I'm asked to do this, but it's apparent others
here have the same problem. In Inventor, I have few options on printing.
1:1 (which will print the center, not necessarily where I want it), Best fit
(which will get the whole assembly on the right sized paper) Model scale,
custom scale (again, only center of sheet) and fit to view (will give me right
area, but not scale). I know I can make a detail view of
area, make a new 11x17 sheet and drag the detail view into it, but golly
that's a lot of work for what should be a cinch. Why not a combination
of print current view and custom scale? That's all I want!
I guess I'll just post this in a wish list and
hope it's in the next release.
"DonA" <Dave,
href="mailto:djanneken@fuse.net">djanneken@fuse.net> wrote in message
printout will be 1:1. If you have it drawn at 4:1, then the printout will be
at 4:1.
paper then it will all fit. If you have it drawn on a different size ("B",
"C"...) then only part will fit on a 8.5 x 11... BUT what does fit will be
at the correct scale I.E. same scale it was drawn at.
So if you want
1:1, then draw 1:1 and select "Model 1:1".
what you do if you want 1:1, then in that case the paper must also be
>=25".
Based on all the posts though, I am not sure that what I
have just said is what you really want. My appologies if I am off base here.
Don A 🙂
"JohnPonikvar" <Sean
href="mailto:john.ponikvar@home.com">john.ponikvar@home.com> wrote in
message
href="news:f14288c.63@WebX.maYIadrTaRb">news:f14288c.63@WebX.maYIadrTaRb...
I think you have something there.
I have yet to meet anyone who can
produce a 1:1 or any other scale for that matter. (I don't get out much so
don't take it to mean I've been around a lot.). But none the less...
No one
I've met has taken the time to correctly understand all that's involved.
Setting up borders (to fit within the print/plot device's print zone), scaling
views in paper space (/ whatever space etc...) then inserting the border at
appropriate scale, scaling text and dimensions etc.. to produce correct size
hard copy. Oh and don't forget to callibrate your printer/plotter. All set?
OK, now do it for each different plotter and printer. It's not like running a
velum through the amonia machine.
No one I've met is interested
printing to scale because it's too hard. (And managements just go along with
it because, well, "at least the print gets out, and it has dimmensions dosen't
it, so who needs a scale? They can read can't they?") No one that is except a
board draftsman. And even then, I've met some who have given up hope because
of the above mentioned degree of difficulty.
I think Inventor is just
pandering to the new breed. Newbies don't care because the tool is too
difficult to figure out. And Adesk thinks its not needed Duh! They sure made
it easy to produce a reasonable hard copy. Just plop in a model or assembly
and IV figures out a view scale for you. Notice the lack of plot device
callibration tool.
Personally I work around if I need a full scale,
which thankfully is rare, so this is a utility low on my IV wish list.
Now
where is that callibration tool?
jp
