Inventor General Discussion
Active Member
christiaan.bowen
Message 1 of 9 (566 Views)
Printing to Adobe PDF with "Remove Object Line Weights" Problem
566 Views, 8 Replies
10-15-2012 02:46 PM
Hello, I am runnning Inventor 2013 Professional 64 bit.  When I print to an Adobe PDF I have selected "Remove object line weights".  The problem I am experiencing is that the result is the same whether it is checked or not.  The result I would expect is that the object line weights won't display on the pdf.  Does anyone have any other suggestions that I could try?  Thanks very much.
Employee
Yijiang.Cai
Message 2 of 9 (548 Views)
Re: Printing to Adobe PDF with "Remove Object Line Weights" Problem
10-15-2012 08:07 PM in reply to: christiaan.bowen
When using R2013 to export IDW to PDF with "Remove Object Line Weights" selected, it works fine for me. So could you attach the dataset for more investigation?
River Cai
Inventor Quality Assurance Team
Active Member
christiaan.bowen
Message 3 of 9 (531 Views)
10-16-2012 09:37 AM in reply to: Yijiang.Cai
River, I have a dataset ready for you and I have tried to post it but can't due to a file size restriction.  The dataset zipped is about 13.8 MB.  Can you provide another location for me to post it to? - Christiaan
Valued Mentor
mpatchus
Message 4 of 9 (525 Views)
10-16-2012 09:39 AM in reply to: christiaan.bowen
Are you "EXPORTING" to pdf or "PRINTING"?
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Active Member
christiaan.bowen
Message 5 of 9 (522 Views)
10-16-2012 09:44 AM in reply to: mpatchus
I am printing to pdf.  The reason is because I have an Excel spreadsheet embedded.  The spreadsheet is unreadable if I export to pdf.  If I print to pdf the spreadsheet is very clear and is searchable.
Employee
Yijiang.Cai
Message 6 of 9 (504 Views)
10-16-2012 10:45 PM in reply to: christiaan.bowen
Thank you to prepare the dataset, and please send me your email and name. So we could provide one location to you to upload the dataset. When the location is ready, one email will be sent to you for details.
River Cai
Active Member
christiaan.bowen
Message 7 of 9 (491 Views)
10-17-2012 08:48 AM in reply to: Yijiang.Cai
christiaan.bowen@tibban.com
New Member
stevecb2
Message 8 of 9 (456 Views)
10-24-2012 12:37 PM in reply to: christiaan.bowen
What was the solution? I'm having a similar problem. I'm using Inventor 13 and trying to print .idw's to pdf with best fit and object line weights removed. Scale is typically .06 to .30.  Inventor isn't removing the line weights, so instead of nice clear thin lines I'm getting some thick dark ones. Didn't have this problem with earlier versions of Inventor.
Active Member
christiaan.bowen
Message 9 of 9 (451 Views)
10-24-2012 12:44 PM in reply to: stevecb2
Steve, I posed the problem to Subscription Help and they are investigating the problem now. Currently I am waiting for a response.
