Inventor Forum
Printing a rendered view
5 REPLIES 5
151 Views, 5 Replies
When I print a rendered view in R6, I end up with extra lines within the drawing itself. I am using a HP 5000n set at 600 DPI. This is a drawing that was produced in 5.3 and printed out just fine. I had to make a minor adjustment to a very simple part and that is when my problems started. Any ideas or will there be a fix in the patch dated Nov. 15th. I have got to ask, what am I supposed to do between now and then if the file has been migrated????
5 REPLIES 5
Known issue.  Hopefully will be addressed in
SP.  Hopefully you have backups of your data in which case you can go back
to 5.3 and plot.  However anything done in R6 is stuck there (at least the
IDWs).
I'm facing some of the same issues.  The plots
really look like <self-edited>
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
remove all #s from
email
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
When
migrated????
If your shaded views do not have dimensions on
them, you could pretty quickly replace them with views that have no hidden lines
(not shaded).  This may be better than all those incorrectly showing lines
in the shaded views.  Not a great solution, but may help until SP1.  I
too am counting on SP1 to have a fix for this problem.
        Ed
R
back to 5.3 and plot.  However anything done in R6 is stuck there (at
least the IDWs).
plots really look like <self-edited>
Sean Dotson, PE
remove all #s from
email
When
migrated????
Sean does a BMP save show the same problems.
I used to save as BMP and then print the BMP when I was doing shaded
assemblies.  Trails used to bleed through.  It was a work around
though.
Kathy Johnson
least the IDWs).
Sean Dotson, PE
remove all #s from
email
When
migrated????
As suspected a saved BMP of the detail looks
fine.  Thanks Kathy...
(Wish I would have thought of that the other
day.)
It looks like it's definitely in the print engine
then...
Sean Dotson, PE
remove all #s from
email
problems.  I used to save as BMP and then print the BMP when I was doing
shaded assemblies.  Trails used to bleed through.  It was a work
around though.
Kathy Johnson
in SP.  Hopefully you have backups of your data in which case you can
go back to 5.3 and plot.  However anything done in R6 is stuck there
(at least the IDWs).
Sean Dotson, PE
remove all #s
from email
When
migrated????
I think I have been mentioning this work around
since the problem was noticed.  I knew if I posted it enough someone would
see it.
Kathy Johnson
day.)
then...
Sean Dotson, PE
remove all #s from
email
doing shaded assemblies.  Trails used to bleed through.  It was a
work around though.
Kathy Johnson
addressed in SP.  Hopefully you have backups of your data in which
case you can go back to 5.3 and plot.  However anything done in R6 is
stuck there (at least the IDWs).
Sean Dotson, PE
remove all #s
from email
When
file has been
migrated????
