Hi everyone,
I am using Inventor professional 2014.
I heard that in this version,
a drawing printing can now be saved so that each time I have a format A to print, it prints format A by default.
Each time I have a format B to print, it prints format B by default.
Where and how do I do that?
Now, if i have a drawing format A and another drawing format B to print, i have to change the format prining page each time.
Thanks a lot,
Sophie
Hi
For 5$ it exist a add-in who will make the job, if i remembe,r i think you can add icon for each printer configuration
Hi Yannick,
Have you tried the program?
I was told that Swift Prints had to many bugs in them.
I this true? And is the program easy to install ? No bugs?
Sophie
Hi Sophie
I never use this program recently, but i think you can try it before bought it
you can try kwikprint32 too (25$) this come from a very good developper with a lot of good stuf on his web site
Hello Mike,
Please post the macro code. I was just about to try to figure it out myself, but if you don't mind sharing, I'll sing your praises.
Sincerely,
David Fletcher
Swift prints for me was never an acceptable solution, I still had to tell it wether I was looking at an A or B size sheet. Inventor already knows what size the sheet is!
I wrote this almost three years ago when I was just learning VBA, so it's not pretty but it does work flawlessly for our whole office:
Public Sub printMacro(ByVal printAll As Boolean, ByVal copies As Long, ByVal plotFullScale As Boolean) Dim oSheets As Sheets Dim oSheet As Sheet Dim sheetNum As Integer Dim totSheets As Integer Dim curSheet As Object Dim sheetSize As String Dim doc As DrawingDocument Dim box As Long On Error GoTo notadwg: Set doc = ThisApplication.ActiveDocument On Error GoTo 0 If printAll = True Then Set oSheets = doc.Sheets sheetNum = 0 totSheets = oSheets.count For Each oSheet In oSheets sheetNum = sheetNum + 1 If sheetNum > totSheets Then Exit For Set curSheet = doc.Sheets.Item(sheetNum) If curSheet.ExcludeFromPrinting = True Then GoTo code: curSheet.Activate If curSheet.Orientation = kPortraitPageOrientation Then doc.PrintManager.Orientation = kPortraitOrientation Else doc.PrintManager.Orientation = kLandscapeOrientation End If If curSheet.Size = kBDrawingSheetSize Then doc.PrintManager.PaperSize = kPaperSize11x17 ElseIf curSheet.Size = kADrawingSheetSize Then doc.PrintManager.PaperSize = kPaperSizeLetter Else code2: sheetSize = InputBox("The current sheet is not formated in a way that I can easily read. Please enter an " & Chr(34) & "A" _ & Chr(34) & " if this is an 8.5x11 sheet or " & Chr(34) & "B" & Chr(34) & " if this is an 11x17 sheet.", _ "Sheet size?", "A") If sheetSize = "A" Or sheetSize = "a" Then curSheet.Size = kADrawingSheetSize doc.PrintManager.PaperSize = kPaperSizeLetter ElseIf sheetSize = "B" Or sheetSize = "b" Then curSheet.Size = kBDrawingSheetSize doc.PrintManager.PaperSize = kPaperSize11x17 ElseIf sheetSize = "" Then Exit Sub Else sheetSize = MsgBox("Invalid entry! Follow the directions!!!", vbOKOnly, "Invalid entry") GoTo code2: End If End If If plotFullScale = True Then doc.PrintManager.ScaleMode = kPrintFullScale Else doc.PrintManager.ScaleMode = kPrintBestFitScale End If doc.PrintManager.AllColorsAsBlack = True doc.PrintManager.PrintRange = kPrintCurrentSheet doc.PrintManager.NumberOfCopies = copies doc.PrintManager.SubmitPrint code: Next Else Set curSheet = doc.ActiveSheet If curSheet.Orientation = kPortraitPageOrientation Then doc.PrintManager.Orientation = kPortraitOrientation ElseIf curSheet.Orientation = kLandscapePageOrientation Then doc.PrintManager.Orientation = kLandscapeOrientation Else doc.PrintManager.Orientation = kDefaultOrientation End If If curSheet.Size = kBDrawingSheetSize Then doc.PrintManager.PaperSize = kPaperSize11x17 ElseIf curSheet.Size = kADrawingSheetSize Then doc.PrintManager.PaperSize = kPaperSizeLetter Else code3: sheetSize = InputBox("The current sheet is not formated in a way that I can easily read. Please enter an " & Chr(34) & "A" _ & Chr(34) & " if this is an 8.5x11 sheet or " & Chr(34) & "B" & Chr(34) & " if this is an 11x17 sheet.", _ "Sheet size?", "A") If sheetSize = "A" Or sheetSize = "a" Then curSheet.Size = kADrawingSheetSize doc.PrintManager.PaperSize = kPaperSizeLetter ElseIf sheetSize = "B" Or sheetSize = "b" Then curSheet.Size = kBDrawingSheetSize doc.PrintManager.PaperSize = kPaperSize11x17 ElseIf sheetSize = "" Then Exit Sub Else sheetSize = MsgBox("Invalid entry! Follow the directions!!!", vbOKOnly, "Invalid entry") GoTo code3: End If End If If plotFullScale = True Then doc.PrintManager.ScaleMode = kPrintFullScale Else doc.PrintManager.ScaleMode = kPrintBestFitScale End If doc.PrintManager.AllColorsAsBlack = True doc.PrintManager.PrintRange = kPrintCurrentSheet doc.PrintManager.NumberOfCopies = copies doc.PrintManager.SubmitPrint End If Exit Sub notadwg: box = MsgBox("Please have a drawing active when using the print macro.", vbOKOnly, "Not a drawing") Exit Sub cancel: End Sub Sub printOptions() printDialog.Show End Sub
You'll also want the form (attahced).
Mike,
Sweeeeet! That is really what I've been needing to stop the profuse bleeding from the center of my forehead for the last 2 years! I can't believe that Autodesk didn't implement something simple like this a long, long time ago.
For other users who sometimes use C and D size drawings, but print them to a run-of-the-mill copy/print machine that doesn't have paper that big, I've added a bit of capability to this code, Mike. It now detects C and D size sheets, then temporarily changes the "full scale" boolean to false so that they will fit on 11x17 (B) size paper.
Nice work! You rock! You are the man.
Sincerely,
David Fletcher
>>> updated code:
Dim oSheet As Sheet
Dim box As Long
On Error GoTo 0
sheetNum = 0
totSheets = oSheets.Count
curSheet.Activate
Call SetSheetSize(curSheet, doc, printAll, copies, plotFullScale)
code:
'Do nothing, we're excluding this sheet.
Next
Else
'We are just printing the current sheet
End If
Exit Sub
notadwg:
Exit Sub
cancel:
End Sub
Sub printOptions()
printDialog.Show
End Sub
Private Sub SetSheetSize(ByRef curSheet As Sheet, ByRef doc As Document, ByVal printAll As Boolean, _
Dim originalsetting_plotfullscale As Boolean
originalsetting_plotfullscale = plotFullScale
Else
End If
ElseIf curSheet.Size = kCDrawingSheetSize Then
doc.PrintManager.PaperSize = kPaperSize11x17 'kPaperSizeCSheet
plotFullScale = False
ElseIf curSheet.Size = kDDrawingSheetSize Then
doc.PrintManager.PaperSize = kPaperSize11x17 'kPaperSizeDSheet
Else
code2:
"Sheet size?", "A")
'curSheet.Size = kADrawingSheetSize
'curSheet.Size = kBDrawingSheetSize
Exit Sub
Else
GoTo code2:
End If
End If
Else
End If
doc.PrintManager.AllColorsAsBlack = False
plotFullScale = originalsetting_plotfullscale
End Sub
@mrattray wrote:
Glad to see it worked for you, that was a scenario that wasn't ever going to occur at our shop as we simply scale the views to whatever we want to and keep our sheet sizes to actual printable sizes.
I agree that Inventors handling of this situation is insane. When I started here I think I did one or two small jobs before I yelled "No more! This needs fixing immediately!"
Hi!
I was looking for this function aswell so I found this on google.
But I don't know how I can put this code into work in Inventor? Could you help me? (I've never used macros and stuff)
Also, I only use A4 and A3 in my work. How can we change the code so it will work for that?
Cause I tried the code and it wont print cause the printer says I dont have the right format. I tried via Microsoft visual basic.
And, can I decide if I want color or B&W?
I hope you can answer this and help me!
Kind regards
calle
@Anonymous wrote:
First of all let me state: "I am not a clever man..." Then: How do I impelment these apparantly very usefull tool in Inventor? It does not appear to be iLogic or...? Could anyone direct me in the right direction?
Hello JJ,
Well, if you want to get this to work, you're going to have to become a cleverer man than you were!
So, to start, find the VBA editor in Inventor. Go to Tools ribbon, Options group, and click on VBA Editor icon.
You have to paste Mike's code or the updated code I posted into one of the "modules" in your vba environment. You also have to get the VBA form that Mike posted. This provides the options for Setting All colors As black, or not, or to print all sheets. I included a button on my version of the form that says "Send large sheets to the Plotter" in case I want to print C and D size sheets full scale. (If I am just testing out a drawing, I default them to scale down to 11X17" paper size.)
Expect to spend a few hours tinkering if you don't know what you are doing. But once you are done, you will not have to fiddle faddle with Inventor's print dialog or your printer's options. I have it set up now so that when I am in Inventor, i hit one keystroke, check the print options, and hit <Enter> and my drawing prints... no matter what size it was created on!
Good luck,
David Fletcher
Here is my Print Dialog Box. (see attached). in the VBA environment, under Application Project (In the project browser on the left of your screen), expand the "Forms" folder. There should be nothing there. Right-click on the Forms folder and select "Import File..." Then select the attachments (from wherever you saved them).
Make sure you copy and paste the code below into a VBA module.
Then you can select a hotkey in Inventor, or add a button to the ribbon to call up the PrintDialog macro that starts off the whole shebang.
And then Bob's your uncle!
David Fletcher
Below is the code that appears in the VBA "module"
Sub printMacro(ByVal printAll As Boolean, ByVal copies As Long, ByVal UsePlotter_forLarge As Boolean, ByVal All_Colours_As_Black As Boolean)
Dim oSheet As Sheet
Dim SheetSize As String
Dim box As Long
On Error GoTo 0
sheetNum = 0
curSheet.Activate
Call SetSheetSize(curSheet, doc, printAll, copies, UsePlotter_forLarge, All_Colours_As_Black)
code:
Next
Else
End If
Exit Sub
notadwg:
Exit Sub
cancel:
End Sub
Sub printOptions()
printDialog.Show
End Sub
ByVal copies As Long, ByRef UsePlotter_forLarge As Boolean, ByRef All_Colours_As_Black As Boolean)
Dim oprtmgr As PrintManager
Dim plotFullScale As Boolean
Dim defaultPrinter, oPlotter As String
oPlotter = "HP Designjet T2300 HPGL2"
Set oprtmgr = ThisApplication.ActiveDocument.PrintManager
defaultPrinter = oprtmgr.Printer
oprtmgr.Orientation = kPortraitOrientation
Else
oprtmgr.Orientation = kLandscapeOrientation
End If
oprtmgr.PaperSize = kPaperSize11x17
oprtmgr.PaperSize = kPaperSizeLetter
Call Decide_Plotter(UsePlotter_forLarge, oprtmgr, oPlotter, plotFullScale, "C")
Call Decide_Plotter(UsePlotter_forLarge, oprtmgr, oPlotter, plotFullScale, "D")
Else
code2:
SheetSize = InputBox("The current sheet is not formated in a way that I can easily read. Please enter an " _
& Chr(34) & "A" & Chr(34) & " if this is close to 8.5x11 sheet," & vbNewLine _
& Chr(34) & "B" & Chr(34) & " if this is close to 11x17 sheet," & vbNewLine _
& Chr(34) & "C" & Chr(34) & " if this is close to 17x22 sheet, OR" & vbNewLine _
& Chr(34) & "D" & Chr(34) & " if this is close to 22x34 sheet,", _
"Sheet size?", "A")
If SheetSize = "A" Or SheetSize = "a" Then
ElseIf SheetSize = "B" Or SheetSize = "b" Then
ElseIf SheetSize = "C" Or SheetSize = "c" Then
ElseIf SheetSize = "D" Or SheetSize = "d" Then
ElseIf SheetSize = "" Then
Exit Sub
Else
SheetSize = MsgBox("Invalid entry! Follow the directions!!!", vbOKOnly, "Invalid entry")
GoTo code2:
End If
End If
oprtmgr.ScaleMode = kPrintFullScale
Else
oprtmgr.ScaleMode = kPrintBestFitScale
End If
oprtmgr.AllColorsAsBlack = All_Colours_As_Black
oprtmgr.PrintRange = kPrintCurrentSheet
oprtmgr.NumberOfCopies = copies
oprtmgr.SubmitPrint
oprtmgr.Printer = defaultPrinter
End Sub
Public Sub Decide_Plotter(ByRef WeWantPlotter As Boolean, ByRef oprtmgr As PrintManager, ByRef oPlotter As String, _
ByRef plotFullScale As Boolean, ByVal SheetSize As String)
If WeWantPlotter Then
oprtmgr.Printer = oPlotter
If SheetSize = "C" Then
oprtmgr.PaperSize = kPaperSizeCSheet
ElseIf SheetSize = "D" Then
oprtmgr.PaperSize = kPaperSizeDSheet
End If
Else
End If
End Sub
Thanks! It's all very helpfull. A4 and A3 are printing perfect on the standard printer, but the plotter is giving me troubles.
Printing A4 and A3 size on the plotter is ok, but setting the paper size to A2 (oprtmgr.PaperSize = kPaperSizeA2) or higher gives following error:
"method 'papersize' of object 'drawingprintmanager' failed"
But kPaperSizeA2 should be a part of the API.
Dim oSheet As Sheet
Dim box As Long
On Error GoTo 0
sheetNum = 0
curSheet.Activate
code:
Next
Else
End If
Exit Sub
notadwg:
Exit Sub
cancel:
End Sub
Sub printOptions()
printDialog.Show
End Sub
oPlotter = "\\192.168.100.8\HP Designjet 500 42+HPGL2 Card"
Else
End If
If curSheet.Size = kA4DrawingSheetSize Then
oprtmgr.PaperSize = kPaperSizeA4
ElseIf curSheet.Size = kA3DrawingSheetSize Then
oprtmgr.PaperSize = kPaperSizeA3
ElseIf curSheet.Size = kA2DrawingSheetSize Then
Call Decide_Plotter(UsePlotter_forLarge, oprtmgr, oPlotter, plotFullScale, "A2")
ElseIf curSheet.Size = kA1DrawingSheetSize Then
Call Decide_Plotter(UsePlotter_forLarge, oprtmgr, oPlotter, plotFullScale, "A1")
Else
code2:
SheetSize = InputBox("Jeg kan ikke genkende den valgte papir størrelse. Vælg venligst:" _
& Chr(34) & "A4" & Chr(34) & " hvis det minder om A4," & vbNewLine _
& Chr(34) & "A3" & Chr(34) & " hvis det minder om A3," & vbNewLine _
& Chr(34) & "A2" & Chr(34) & " hvis det minder om A2, Eller" & vbNewLine _
& Chr(34) & "A1" & Chr(34) & " hvis det minder om A1,", _
"Str.?", "A4")
If SheetSize = "A4" Or SheetSize = "a4" Then
ElseIf SheetSize = "A3" Or SheetSize = "a3" Then
ElseIf SheetSize = "A2" Or SheetSize = "a2" Then
ElseIf SheetSize = "A1" Or SheetSize = "a1" Then
ElseIf SheetSize = "A0" Or SheetSize = "a0" Then
Call Decide_Plotter(UsePlotter_forLarge, oprtmgr, oPlotter, plotFullScale, "A0")
Exit Sub
Else
SheetSize = MsgBox("Den går ikke! Læs vejledningen igen!!!", vbOKOnly, "Forkert indtastning")
GoTo code2:
End If
End If
Else
End If
oprtmgr.SubmitPrint
End Sub
' Ved plotter størrelser skal der vælges "custom size"
' ' Change the paper size to a custom size. The units are in centimeters.
' oPrintMgr.PaperSize = kPaperSizeCustom
' oPrintMgr.PaperHeight = 59.4
' oPrintMgr.PaperWidth = 84.1
If SheetSize = "A2" Then
oprtmgr.PaperSize = kPaperSizeA2 'Custom
'oprtmgr.PaperHeight = 29.94
'oprtmgr.PaperWidth = 21.59
ElseIf SheetSize = "A1" Then
oprtmgr.PaperSize = kPaperSizeCustom
oprtmgr.PaperHeight = 59.4
oprtmgr.PaperWidth = 84.1
ElseIf SheetSize = "A0" Then
oprtmgr.PaperHeight = 84.1
oprtmgr.PaperWidth = 118.9
End If
Else
End If
End Sub
Hi
Hi JJ,
I think the problem is with your name for oplotter. When I wrote me code, there was no network path in the name for oplotter. It looked like this:
So if you have anything that is not EXACTLY the right name for that printer, as soon as you call oprtmgr.PaperSize (you are actually accessing the printmanager object now) it fails because it can't find a printer with that EXACT name. There is probably nothing wrong with the paper size. You could try using the numerical equivalent (14339) to see if that changes anything. But I expect it is the name of the printer that is wrong.
You are almost there! Or you have already figured this out, and have gone on your way, happy to be done with this silly issue!
Good luck,
David Fletcher
