Inventor Forum
Printed Line Weight
3 REPLIES 3
marxtrain
1706 Views, 3 Replies
Printed Line Weight
I am trying to cut out a few parts that I have made in inventor on a laser engraver.  In order to cut properly, the printed line weight of the drawings (what the document would look like when printed out on a piece of paper) needs to be between .001 and .007 inches.  Is there any way to change this setting in an Inventor drawing file (.idw)?
3 REPLIES 3
blair
in reply to: marxtrain
The only place that I can think of, is in the Styles and Standards. Look in the Layers, it may take a bit of hunting to find the correct layer.
The only other way would be to select and change each line by itself and change if from Layers to Line Weight and change the weight of the Line
Delta Tau Chi ΔΤΧ
mcgyvr
in reply to: blair
Line weight is in the style/standard library as Blair stated.
marxtrain
in reply to: blair
This worked great.  Thanks so much.
