Inventor Forum
Print drawings from a VBA script
5 REPLIES 5
pball
3350 Views, 5 Replies
I've searched for this a bit and didn't find anything that helped me much. So I'm mostly wondering how possible it is to print drawings using a VBA script. I'm interested in forcing print size and the best fit setting.
So if anyone has links or some code to share I would most appreciate it. Searching for printing/plotting yields more results about saving to dwg/pdf than printing to paper.
5 REPLIES 5
brendan.henderson
in reply to: pball
Here is a link to a macro I posted previously. Read the caveats and subsequent posts-it's not perfect but it works.
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Printing-all-drawings-of-an-assembly-f...
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
pball
in reply to: brendan.henderson
Thanks I'll take a look at it.
mrattray
in reply to: pball
I have one I use that's intended to be run from an idw. It prompts asking if you would like to print the current sheet or all sheets and for number of copies, forcing all other settings. I wrote it because Inventor doesn't play well with our document center and the switching between 11x17 and 8.5x11.
Let me know if you want me to post up the code.
Mike (not Matt) Rattray
pball
in reply to: mrattray
mrattray that would be most appreciated. That's exactlly what I'm looking to do. Well that and throw in a loop to do multiple drawings in a batch.
mrattray
in reply to: pball
Code attached. Copy/paste the text file contents into your application project and use file/import file to bring in the .frm file. I'm honestly not sure what the frx file is, but Inventor outputs it when I export the form. I use a template level ilogic rule to call the macro.
