Solved by Curtis_Waguespack. Go to Solution.
My company using Inventor 2011 and I need to put some type of date and time in the bottom right of the idw.
I found this wish from Google search and wonder if the wish come true yet.
I need the same thing any one help?
No this is not supported by Inventor still but here is some code that gets you pretty darn close.
http://forums.autodesk.com/t5/Autodesk-Inventor/print-date-and-time/m-p/2462640#M337712
Four years later. Is this still the case? there is no great method other then the ilogic routine in your link?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi Cadmanto,
Here is a link to the exhange app that nmunro mentioned:
Additionally, there is some iLogic at this link, along with an attached example *.idw file:
I hope this helps.
Curtis
Thanks Curtis and Neil.
We are needing to put this in our formats and seeing this was a 4 year old thread that lead to a 2 year old thread, wasn't sure if something hadn't been done further about it. This should really be an idea as a standard drawing property to input into the drawings.
Yes, please include a TIME STAMP feature !!
This is VERY HELPFUL for users like me that print several sheets of the same design after making small changes each time and then traveling to my printer after all have printed and mixed up by someone else who beats me to the printer 😞
