Solved by blair. Go to Solution.
That should do it, I would make one change to the "Look at Skect on Creation", exit Inventor, then re-open Inventor and make the change back to Look at Sketch. Inventor writes the changes upon proper exit of Inventor. Uncheck selection, then exit IV, open IV and select Look At Sketch. Before you start Inventor, open the Windows Task Manager and see that there are no other instances of Inventor running. This will not allow the updates to be written.
