Really simple question, hopefully there's a simple solution. I have a flexible sub-assembly in my top assembly. Sometiems I'm trying to demonstrate to others how a mechanism in the sub-assembly works using this flexibility feature. It works great, but when I move just one little part of a flexible assembly, Inventor displays the wire-mesh of the entire flexible assembly, because technically the entire assembly is selected, even though I'm only moving one part. It clutters up the screen very badly, detracting from what I'm trying to show.
Is there a way to prevent Inventor from displaying the selection lines? Either only when I'm moving a part in a flexible assembly (which would be great), or to just turn them off completely when I'm presenting like this? I know I can turn off pre-select, but that doesn't help, because once I start moving a part in the flexible assembly, the assembly is "selected" and the wire-mesh displays. Any suggestions would be appreciated. Thanks!
Solved by Ray_Feiler. Go to Solution.
Try Select Part Priority.
I want to be able to click and drag so I can have complete control over the part. But thanks for the suggestion, James.
Ray, great suggestion! That looks like it'll work, thanks!
