Scott,
In this and my previous job we made one off's as well. When a project was
done we would pack and go it to a directory and then also burn a copy of the
library onto the CD as well. That way you could load the entire library and
project back onto a system that didn't have it before. (if the library path
is different you will have some resolution problems the first time out but
after that all is well).
I don't envy your library renumbering task
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Scott Stubbington" wrote in message
news:D2290354C35FFD3512E33557CD1CBD6E@in.WebX.maYIadrTaRb...
> Hello,
> I need to Pack and Go about 1½ years worth of IV work. The problem is
that
> due a company change, we were sold, we now have a new numbering system.
In
> order to preserve all the files used by an assembly I would like to P&G
all
> these files, that I think would be the easiest way. We sell one offs and
> just in case the customer reorders I feel this is necessary.
> If this isn't bad enough, obviously I'm to renumber my entire library.
> Any thoughts would be greatly appreciated.
> Thanks
> Scott
