So what's the tip on getting the same camera view at the end of the
presentation same as you started with at beginning? If you start say zoomed
out on an iso then you assemble ending with completed assembly, then record
auto reverse it goes ok till you get to last camera view which is the first
move to (zoomed in on a component) then if the AVI is on repeat it jumps at
the end/start, ok I just tried it it is seamless but does not go back to my
start view, cause I did not save a camera I need a sequence to do this? So I
make a sequence with a miniscule tweak?
Laurence,
Power is nothing without Control
"Cory McConnell" wrote in message
news:224D4BE1D94DB8D8FBB9FF3AADA5221D@in.WebX.maYIadrTaRb...
> You bet it can. Out of all the features of Inventor that I have played
> with, ipns have to be right up there in difficulty. You have to think so
> far ahead when doing tweaks so you end up with an easy to follow
explosion.
> And with large assemblies, they get really slow.
> Cory McConnell
> BJ pipeline Inspection
