Inventor Forum
Precise input when moving an item is sketch
4 REPLIES 4
295 Views, 4 Replies
I can't seem to find the combination of things to use precise input when
trying to move a rectangle from where its at to -13,-13mm.
This seems simple enough but I can't get the accept to be not greyed
out.
Thanks for the help, Rich
4 REPLIES 4
I don't think you can use precise input with the move command. Move wants
two points. You could create a work point (using precise input) then move a
point on the rectangle to that point..
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Rich" wrote in message
news:398D7993FE85A372900F08BCB206689D@in.WebX.maYIadrTaRb...
> out.
Sean,
I'm sorry to tell you that Precise Input is very useful when moving a sketch
without having any existing points, the "trick" is to press Enter in the
precise input dialog after the values are entered to get the Move command to
accept the values as a selection.
"Sean Dotson" wrote in message
news:5F88D6C9F8B2BB5115DE4F404A1A8D93@in.WebX.maYIadrTaRb...
a
> Sean Dotson, PE
> > out.
Don't be sorry Patrick, that is great news.
Hal Gwin
Mechanical Designer
Xenogen
Never be sorry to correct me. Thanks for the tip!
Sean Dotson, PE
"Patrick de Stobbeleir" wrote in message
news:D443AB03B903B6F8E228049BAE3EBAEA@in.WebX.maYIadrTaRb...
> Sean,
sketch
to
wants
move
> a
> > Sean Dotson, PE
when
> > > out.
