Inventor General Discussion
New Member
drhoads51
Message 1 of 6 (1,081 Views)
Precise Input toolbar
1081 Views, 5 Replies
03-19-2012 07:07 AM
One of my students has moved their precise input toolbar. How do I bring it back?
JDMather
Message 2 of 6 (1,080 Views)
Re: Precise Input toolbar
03-19-2012 07:29 AM in reply to: drhoads51
Why are you using Precise Input toolbar?
I recommend you forget you ever saw it.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
New Member
drhoads51
Message 3 of 6 (1,077 Views)
03-19-2012 07:37 AM in reply to: JDMather
I'm using it because we are teaching the coordinate system and basic graphing.
JDMather
Message 4 of 6 (1,066 Views)
03-19-2012 08:15 AM in reply to: drhoads51
I suspect that there might be a better technique.
Attach the assignment here.
You have not indicated what environment you are in or any screen shots or other information.
Assuming 2D sketch environment - edit the sketch (or start a new sketch as appropriate).
Start one of the sketch commands (like line).
Click on the down arrow next to Draw (wait a minute - you did say you are using 2010 or later with Ribbon Interface?).
You should see command for Precise Input (this can be promoted to main tab if desired).
New Member
richpark
Message 5 of 6 (944 Views)
12-18-2012 07:39 AM in reply to: drhoads51
The nput fields have dissappeared from the Precise Input bar.  They worked fine yessterday.
FYI - The reason we use the "precise input" is because it is part of the PLTW curriculum.
JDMather
Message 6 of 6 (930 Views)
12-18-2012 10:25 AM in reply to: richpark
Whoever wrote that curriculum doesn't know what they are doing.  Find a better and more efficient technique.
I remember my first CAD class back in '87 of the last century.  First day we were taught to use similar technique (grid).  I turned it off next day and ignored any suggestions to use it.  Never looked back.
Post screen shot of what you are seeing with the Precise Input toolbar.
