Resetting F6 didnt help, in my opinion Z is in the wrong direction, can this be reversed? Being Mechanical I see X as being to my right, Y is elevation (as in reading an x-y graph, so xy is front plane) and Z is AWAY (xz is top, zy is right side) from me (Civils who look at the ground see Y as being away from them and Z as elevation). I expect if you wrote "plane" on each face, when you hit iso view you should be able to read each word left to right but i cant get this either with default std ipt, std in ipt or std mm ipt. Have I changed a setting or something?
