Inventor General Discussion
JDMather
Message 61 of 65 (223 Views)
Re: Posting a project for comments
05-09-2012 04:16 AM in reply to: donovandigital
I dimension or constrain everything.  Geometric constraints are (should be) obvious and take the place of many (most) dimensions.
The dimensions are the dimensions that will be needed out on the shop floor.  By fully constraining everything you ensure that the model is not accidently released for manufacture with a missing dimension.  (I worked out on the shop floor for 8 years - I can tell you that missing dimensions is a costly problem.)
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
JDMather
Message 62 of 65 (211 Views)
05-09-2012 05:52 AM in reply to: donovandigital
donovandigital wrote:
Really hope I can build this....
Did you verify the specs on the threads.
As indicated earlier 7mm is an unusual thread.
Valued Contributor
donovandigital
Message 63 of 65 (200 Views)
05-09-2012 07:43 AM in reply to: JDMather
Re dimensions, that is what I thought.
Re thread
To be honest I don't know how to check this. Can I do this with calipers?
Joe
JDMather
Message 64 of 65 (173 Views)
05-09-2012 01:05 PM in reply to: donovandigital
Measure the diameter of the thread.
Typically it will be slightly undersize.  A 7mm thread might measure something like 6.8mm.
Find the pitch by measuring the distance across the crest of 11 threads and divide by 10 (you can just measure the distance from one to the next, but it is sometimes easier to get 10 distances and move the decimal place)
The diameter and pitch should match the list in the aviable Hole Feature.
Yes, use calipers.  (there is a special tool to find pitch, but you can do this with calipers as described.).
You could also go to the local hardware store and purchase several nuts of sizes close to what  you think you measure. (Be sure to keep them labeled.
You measure the external thread diameter (rod) not the hole.
Valued Contributor
donovandigital
Message 65 of 65 (157 Views)
05-09-2012 04:38 PM in reply to: JDMather
Will do so this week
But - are all the parts I posted OK?
Thanks again
Joe
