I know. Project an axis or a plane then reference to that projected
geometry.
..or am I misunderstanding you?
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Ken Schumacher" wrote in message
news:2389EED48098F257520D3EA2A501EA14@in.WebX.maYIadrTaRb...
> There is no existing hole to project.
> "Sean Dotson" wrote in message
> news:7ADD77DC3218582C4275757C53DD8FB0@in.WebX.maYIadrTaRb...
> > just project geometry as you normally would in an assembly...
> > Sean Dotson, PE
> > news:832B0D6091C92010A475734CDB538A29@in.WebX.maYIadrTaRb...
> > > I have two tubes that I have welded together. (one inside the other)
> > > I now want to tap a hole thru both tubes to the centerline of the O.D.
> > > When I create a sketch in "Machining" how do I constrain or dimension
my
> > > point or hole center?
> > > I hope I'm missing something here real blatant.
> > > Thanks,
> > > -Ken
