The punch formed does not allow me to face up the correct way when applied.When i place the punch it always is inserted up side down.It faces down instead of facing up.The punch works as it always inserts but what needs to be changed to get it have the dimple on the up side and not the under side?
Rich - inv2013
I did select the face from the 2nd tab originally but it still places the punch on it side when punch placed on point.I then select the face but it still places the punch on the underside of the sheet metal part.I thought the punch would sit flat on the face chosen
Hi Mike
Nothing attached.Sometimes for some reason it hard to attach files....i will give it another try
regards
Rich
