I have 2 tanks, each one is an assembly in itself, and they have to be positioned on a steel skid, also an assembly and then interconnecting pipework between the two. My prioblem is that I can't seem to find a way to position the two tanks at a set distance from each other and in relation to the edges of the skid.
Because of this, my pipe router is going all over the place in trying to join up the two termination points.
Any suggetsions?
Rhoscadman
Are we talking about something other then a distance mate?
Can you post some images with further explaination?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Vertical or horizontal tanks? If vertical, create an axis on each tank and constrain them a distance apart and from the edges from the skid. You can also use the planes in the tank assy file to position them in exact orientations
or at least post a screen capture
Thanks for the prompt help, folks. I appreciate that.
Yes the constrain between the edge of the skid and tto the edge of the holding down lugs, plus an offset distance seemed to do the trick
Once again, many thanks.
Rhoscadman
