Inventor General Discussion
Active Contributor
0 Kudos
Post 1 of 5
Positioning 2 sub-assemblies exactly
4653 Views, 4 Replies
03-25-2013 10:35 AM
I have 2 tanks, each one is an assembly in itself, and they have to be positioned on a steel skid, also an assembly and then interconnecting pipework between the two. My prioblem is that I can't seem to find a way to position the two tanks at a set distance from each other and in relation to the edges of the skid.
Because of this, my pipe router is going all over the place in trying to join up the two termination points.
Any suggetsions?
Rhoscadman
Vertical or horizontal tanks? If vertical, create an axis on each tank and constrain them a distance apart and from the edges from the skid. You can also use the planes in the tank assy file to position them in exact orientations
1,281 Kudos
Post 2 of 5
Re: Positioning 2 sub-assemblies exactly
03-25-2013 10:42 AM in reply to: rhoscadman
Are we talking about something other then a distance mate?
Can you post some images with further explaination?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Active Contributor
1 Kudo
Post 3 of 5
03-25-2013 10:51 AM in reply to: Cadmanto
780 Kudos
Post 4 of 5
03-25-2013 04:41 PM in reply to: rjezuit
or at least post a screen capture
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
Active Contributor
0 Kudos
Post 5 of 5
03-26-2013 01:34 AM in reply to: rjezuit
Thanks for the prompt help, folks. I appreciate that.
Yes the constrain between the edge of the skid and tto the edge of the holding down lugs, plus an offset distance seemed to do the trick
Once again, many thanks.
Rhoscadman
