Could someone please remind me of how to set / change the default location of the view identifier for views in an Inventor drawing. By default when I'm creating a new view this appers above the view however I wish for it to be below the view. Thanks
Solved by cbenner. Go to Solution.
In your drawing, or your drawing template file, open the Style and Standard Editor. Manage\Styles Editor.
Under your Standard name, there is a tab for View Preferences. Set it there in your template and all new draings will default that way.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Perfect thanks
