Inventor General Discussion
Distinguished Contributor
5 Kudos
Post 1 of 5
Pos Rep Question
176 Views, 4 Replies
07-10-2013 07:38 AM
I have an assembly with 2 pos reps.  When I activate one or the other of the pos reps the whole assembly jumps.  I have the main part grounded.  I tried to ground other parts but this still happens.  Any idea why this happens and how to fix it?
Steve Frey
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
I figured it out.  I replaced the "base" or original grounded part.  Seems to work now.  Thanks.
269 Kudos
Post 2 of 5
Re: Pos Rep Question
07-10-2013 07:49 AM in reply to: SteveFrey
Is the assembly actually changing position relative to the origin, or is the view just panning?
Cameron Whetten
Inventor 2012
5 Kudos
Post 3 of 5
07-10-2013 08:35 AM in reply to: cwhetten
the assembly looks like it is changing position.  I noticed it in the .IDW.
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
269 Kudos
Post 4 of 5
07-10-2013 08:56 AM in reply to: SteveFrey
Maybe it is just the drawing view moving on the sheet?  You can verify if the assembly is actually changing position relative to the origin by measuring the distance between a component and an origin plane in one positional rep, then change the positional rep and measure between the same two entities.  If the distance is not the same, then that component has moved.
If it is just the drawing view moving, then there is something else going on.
Also, if you can post a data set, it would help.
Cameron Whetten
Inventor 2012
5 Kudos
Post 5 of 5
07-10-2013 09:17 AM in reply to: cwhetten
Steve Frey
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
