When rotating a part or an assembly, I sometime get poor quality display that come back normal when not rotating.
Actually, I get one more complex part that is showing approximated curved edges with lines. The simpler parts are displayed correctly.
- Display quality is set to Smoother
- Changing minimum frame Hz doesn't help
- I disabled the integrated intel GPU (in the bios)
- I have good hardware, it shouldn't be a problem
I thing somehow Inventor decided this complex part should be approximated
Any other settings I can change ? Maybe a value directly in the registery ?
Please post your hardware specs. Are all drivers up to date? Also, what version of Inventor is this?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
IV 2014 SP1 Build 222
windows 7 pro
Dell M6600,
I7-2760qm
16Gb memory
quadro 4000m, driver 320.92
thanks
