Using my ipt flat pattern, I export the face as a Rel. 12 dxf for the file to be used in our cnc software.
I'm having a problem that the guy in the shop cannot open the dxf unless I open the dxf in Autocad and explode it.
Inventor is creating the perimeter as a polyline.
Is there any setting I can change to prevent the polyline creation?
I have also noticed that, in some instances, through the bend area, that after I explode the file, there will be like 127 lines on top of each other.
Again, is there a setting I can change to prevent all of this?
Thank you very much for your help.
Solved by mrattray. Go to Solution.
Instead of using export face, right click on the flat pattern node in the browser and select Save Copy As. After you name and place the file an export options wizard will come up with all sorts of options that you can define and save to a ini file, including wether or not to use polylines.
Thank you very much.
That worked perfectly after a couple of
tweaks with the layers and saving the
configuration.
