I have a sheet metal part I need to show as polished aluminum diamond plate on one side of the material only, just as it would appear on the actual part. Can anyone help me with this?
Inventor 2013
PE
Solved by karthur1. Go to Solution.
Right click on the face you want and choose properties. It is going to show the list you have selected in the appearance browser.
The material I am using is Aluminum 6061. I have tried to change the face properties but the diamond plate choices are not available. I am wanting it to appear similar to the attached jpg file.
PE
By adjusting your color styles, you should be able to create a fairly realistic version.
Here are the settings I used to create this plate.
Changing your Visual Style to REALISTIC will improve the appearance.
Also try a different reflection image in your Inventor Color Options.
First, make sure your have either the Inventor materials or Autodesk materials library selected in the Apperance browser. Right click on the surface and select the diamond plate2-Dark Gray.
Now go to the Tools tab, materials and apperance panel and click the appearance tool. the diamond plate 2- Dark grey should be in the list at the top. To edit the scale and appearance of this right click on the image and chose "edit".
Like Mike says, you will have to change the color/scale to get it the way you want. once you get this right, right click on the image again and choose Add to>Favorites if you want to use this in other documents.
