Ah shucks ... on second thought don't think that chord formula will work by
dividing it because while we would be talking about chord lengths, don't
think they would divide correctly because the total chord length at it's
angle wouldn't be the same as the individual chords at their angles. Oh
forgot ... yes I need even and odd hole counts. What do you mean by linear
offset solution?
~Larry
"Larry Caldwell" wrote in message
news:C1C0D755131E67B77351355EF2CB65B6@in.WebX.maYIadrTaRb...
> Good thinking Darv! The (cordal length / count) should be the pitch of the
> hole pattern and the calculated chordal length should equal what I've been
> calling RowWidth or pitch. Having brought that up, it might be that the
> formula for chordal length could be plugged into my parameters to get what
I
> have in mind. Now the question becomes: how come I didn't think of that
> before. Thanks Darv now I have a lot of ways to go it would seem.
> ~Larry
> "darvinv" wrote in message
> news:6215E67C3625B8C0FFB0793655941FC8@in.WebX.maYIadrTaRb...
> > Larry, unconfuse me
> > I think we've got a classic circular reasoning problem here.
> > Are you really trying to work toward a radial distance solution, or
> > are you more interested in chord lengths? ie, linear offsets. Does it
> > need to solve for even and odd hole counts? The 5" dim that you called
> > arclength will preclude a radial solution, but will allow for a linear
> > offsets solution. Either way, I think polar pattern is involved. I
> > guess intent is always the 64k question.
> > "rowcount" vs "angle of throw" or "distance of throw"? With a 1"
> > pitch length as the final solve.
> > darvin
> > news:1F46BB0F0392DB1122B81062CB569190@in.WebX.maYIadrTaRb...
> > > Actually I started out with a sketch pattern but that's where I first
> > ran
> > > into the problem of trying to get the linear distance I want in the
> > params
> > > to actually be the length of arc for the hole pitch.
> > > ~Larry
> > > news:506E33629AEEEFCD708F8308B8DFC477@in.WebX.maYIadrTaRb...
> > > > Yeh, and the mirror suggestion doesn't do even numbers. There's a
> > way,
> > > > but I'm not sure yet. Just a glimmer of an idea. You may have to
> > base it
> > > > on a sketch pattern, instead of a feature pattern nad use some trig
> > to
> > > > drive the sketch. Then, I think? that way you can accommodate even
> > and
> > > > odd numbers.
> > > > darvin
