Does anyone know what the file size limit is for importing point clouds into Inventor? Or is that a how long is a piece of string question that depends on computer ability?
Adrian
Or, how many licks does it take to get to the center of a tootsie pop.
Don't know. But maybe if you contact someone in the Autodesk 360 group they might be able to give you some direction on this.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I think this would be better served under ReCap. Or,
<jedimindtrick>This is not the cloud you are thinking of...</jedimindtrick>.
