When insert Point Cloud Data Attached in Inventor Part like reference this element
is not displayed into the Drawing Module (IDW)when create a base view
I think is very helpful when we are working with reality capture data to complement existent building information to the new facilities arrangements drawings in 2D for suppliers
Any help about this issue?
Software info
Product Design suite Ultimate 2015
Inventor 2015 Update 2 applied
Even when I try to share this hybrid to navisworks Manage 2015 the workflow is not simple
because the reference between ipt and rcp file is not known by Naviswork.
In this example when insert the rcp in Inventor i rotate -90 dregrees and move the set of data to the origin in Inventor before to create a solid feature
But when Naviskwork open the IPT file only display the solid geometry and if I try to append independent the cloud point data
this is lost the rotation and position where was located into Inventor.
Second scenario
I try a similar example but in this case change Inventor for AutoCAD
Point Cloud Data (*.rcp) -----> AutoCAD 2015 ----> Add 3d geometry ------> create 2d Drawing ---->Result Good but not excellent
Point Cloud Data (*.rcp) -----> AutoCAD 2015 ------> Add 3d geometry ------>SAVE as DWG-------> Open DWG in Naviswork Manage 2015 -->Result Very Good
The results are more aceptable ...please check my images
Now i wil try the same but changing REVIT for AutoCAD
