Inventor General Discussion
martinpeters
Message 1 of 3 (544 Views)
Plot stamp time/date and file location.
544 Views, 2 Replies
07-15-2013 02:06 AM
Does anyone know how to add the plot stamp time/date and file location when printing  in autodesk inventor the same as in Autodesk.
So far this has eluded me.
Regards
cwhetten
Message 2 of 3 (523 Views)
Re: Plot stamp time/date and file location.
07-15-2013 08:53 AM in reply to: martinpeters
Hi and welcome to the forum!
Unfortunately, there is no built-in way to do this.  This is going to involve some programming, either in VBA or iLogic.
This question has been asked on the forum many times, so doing a search should turn up a lot of posts on the subject.  Here are a couple to help you get started:
ilogic plot stamp
Drawings Stamp with Date
Here is the iLogic rule we use (also attached as a TXT file):
Dim odrawdoc As DrawingDocument
odrawdoc = ThisApplication.ActiveDocument
customPropertySet = odrawdoc.PropertySets.Item("Inventor User Defined Properties")
Try
      prop = customPropertySet.Item("iLogicPrintDate")
Catch
      customPropertySet.Add("", "iLogicPrintDate")
End Try
Try
Dim PlotDate As Date
PlotDate = Now
iProperties.Value("Custom", "iLogicPrintDate") = PlotDate
Catch
End Try
InventorVb.DocumentUpdate()
 This code creates a custom iProperty called iLogicPrintDate, then reads the current date and stores it to that iProperty.
We have some text in our drawing border that displays the values of several properties: drawing creator, iLogicPrintDate, and file path and name.  This is what it looks like:
And this is what it looks like when the values are populated:
I think it would be a simple thing to include the time as well as the date.
We also set an iLogic event trigger to run the rule that updates the date when the drawing is saved.
Post back if you have any more questions.
Cameron Whetten
Inventor 2012
Valued Contributor
methoni
Message 3 of 3 (497 Views)
07-16-2013 12:58 AM in reply to: martinpeters
Thanks Cameron
It looks a fairly complicated procedure,something that needs to be done when i have a little more time, i am surprised that
Autodesk inventor being as sophisticated that it is that this was not a regular inherent built in tool as in Autocad.
Regards
