Inventor Forum
Please help with flat pattern
32 REPLIES 32
Message 1 of 33
jeregonn
775 Views, 32 Replies
I am having trouble finding a work around to get this part into a usable flat pattern. I received the part originally as a stp file. I am running autodesk Inventor 2010. Any help or advise would be greatly appreciated.
32 REPLIES 32
Message 21 of 33
jeregonn
in reply to: jeregonn
This is what I have so far. How do I get the part I have drawn to match up to the part I am re-creating?
Message 22 of 33
mrattray
Why did you do this again?
Anyways, once you replace that duplicate dimension with a tangent constraint go ahead and use an unfold feature, then use the hole feature for the round holes and a cut feature for the notch, then use refold to finish the model.
Mike (not Matt) Rattray
Message 23 of 33
jeregonn
in reply to: mrattray
I do not understand how I would know where to locate the holes
Message 24 of 33
JDMather
Create Axis through the holes of the original part and perhaps some workpoints at intersection of axis and projected part face and then create a dimension a drawing.
You are probably going to have to experiment a bit because of bend stretching, but designers tend to use nice easy numbers for the finished center-to-center distances and angles.
Message 25 of 33
jeregonn
in reply to: JDMather
Ok, thank you for your patience. I had some trainging a few years back but it was in 3D modeling only. We didnt even touch on sheet metal tools and now I have a job at a sheet metal fab shop.
I will attempt this and post my resluts.
Message 26 of 33
JDMather
If you don't get it figured out - just hollar back and someone will find a solution.
Message 27 of 33
mrattray
"Hollar back"? Smiley LOL
Message 28 of 33
jeregonn
To make this easier we are going to be locating the holes on the formed edge after the part has been formed.
This is where I am at with the part now. I have located the holes on planar piece of this but am having trouble getting the profile of this feature cut out.
Message 29 of 33
JDMather
This sketch isn't very good quality - if you zoom in here close you will see there are actually two arcs.
Double arc.JPG Also two arcs and overlapping at other end.
Message 30 of 33
jeregonn
I projected the geometry from the customers model to a sketch and then copied that sketch and placed it on my part to aid in locating the features.
Message 31 of 33
JDMather
I always change projected geometry like this to Construction linetype.
Message 32 of 33
jeregonn
Should I be able to trace around the projected geometry and cut away the mat'l I do not want?
Message 33 of 33
JDMather
Yes, of course you can - but you have to create clean sketches rather than those overlapping non-tangent arcs.
Keep in mind that designers use nice regular numbers for arc sizes - dimension them!
