Hi guys,
Sorry for the silly question, but I have drawn this part and can't find a way to... not even sure how to descrive it. You can see in the picture below, I need to replace the yellow edge by the green one.
What would you suggest? Part's in the attachment.
Thanks!
Solved by JDMather. Go to Solution.
One method would be to Loft a surface and the Split or Sculpt.
But I would almost certainly first
constraint all sketches (how or why does one get a perfect Sketch1 without any dimensions)?
Fix sketches 7 & 10.....
